The only force compressing the springs is the weight of the vehicle. Because the weight of the vehicle is enough to compress the suspension a little bit, it’s no longer in a preloaded state. The weight of the vehicle is pressing down and the springs are pushing up. The forces are in equilibrium and preload is irrelevant.I understand the theory but its when it get pratical that I'm not sure. I feel i can't agree that prelods "only change ride height".
Yes the force taken to push a spring is proportional but adding 5 pounds when the springs is already stocking 30 pounds in enery is tought. Its like a powerlifter, if he lift heavy adding 1 pound is going to feel heavier than before. So there is a progression in what we feel. + 1 pound when you lift 20 pounds doesn't feel the same as if you add 1 pound and lift 300 pounds. The initial force when you turn is huge but after that the spring just want to release the energy stock in it.
The only point i try to make is that "ride height" sounds oversimplified to me. Stiffer springs will have an affect on ride height because its stiffer. How i see preloads is how much force added i need to push the spring first. And like i said before, maybe its the concept of "riding height" that i didnt quite understood. If i understand what u wrote is that the spring will react the same but at different height. I think i get that. For exemple if you put 1/2 inch preloads its gonna be higher standing still but the car will go down higher too.
I tried softer springs with alot of prealoads and it was wierd. I had the right height when the car was standing still but if i put the chassis to the ground, it wont go up.
What i want to achieve is a slightly higher ride height BUT i want the suspension to use all the travel it has.
The thing that i dont understand about ride height is why when i put preloads in the rear it start at somepoint to just spin the wheels. If its only about ride height i should have the same grip but with different ride height ?
This doesn’t mean we can expect the car to handle the same: raising or lowering the chassis affects load transfer in all directions, roll centers, and driveshaft angles. These have a significant impact on handling. But the one thing that remains the same is the spring rate.
When the suspension goes through its travel, the wheels move out and/or in because of the changing A-arm angle. Also, the wheels will have some camber gain especially if you run a high roll center. This causes the tires to scrub sideways and the springs are working to overcome it. There’s also the friction from the suspension linkage and shocks themselves. This is why ride height is measured after drop-rolling the car or just pressing the chassis to the ground and measuring how far it rises. The latter method is more common with touring cars. Off-roaders usually like to drop the car.
Ride height is a dynamic thing even on a smooth track, because putting power through the drive shafts stiffens the CVA joint, any toe-in of the rear wheels pushes them together and resists the wheels from scrubbing out, and anti-squat raises the chassis on power but creates an opposite force (pro-dive) when braking.
However! You are correct when you say it’s oversimplified to say the preload only adjusts ride height and nothing else. Changing the ride height changes the geometry love triangle of the shock mounting holes at each end, and the hinge pin. Raising the ride height makes the angle between the shock and A-arm a little slacker, so forces coming from the wheels and pushing up have a little bit more mechanical advantage for compressing the shocks.
P.S. Different spring rates are not a ride height adjustment. Changing springs always involves setting the preload to get the desired ride height.
If you change spring rates without setting the preload, the amount of preload was incorrect for one of the springs and the comparison is moot. It’s like putting an E string to the lowest spot (G) on a violin, cranking it up to the same tension as before, and wondering why the instrument is out of tune.
