easy rider
I was running my OS 21 T-Maxx yesterday. I put the Revo tires back on it. I have everything adjusted right for straight tracking. And, it does track straight. Unless I hammer it.
When I give it wot and it hits second gear it blows out of the hole. The problem is it starts going left as it accelerates. It’s not bad. But, it needs to be corrected to stay with on narrow areas.
I didn’t notice it in gravel or dirt. But, on pavement, it’s an issue. I’ve checked the setup. Everything is in line like it should be. Nothing is loose on the steering or chassis. I can’t find an issue causing it. The only thing I can attribute it to is it breaking traction. Occasionally, it’ll pull right too.
I’m out of ideas that could be causing it. While minor, I do want to fix it if something is wrong. How about it? You guys got any idea on what’s up? Or, is it just breaking traction with that one wheel when it hammers into second gear?
