New Associated SR10M Dirt Oval RTR
DavidB1126
Team Bomb Pop
Baltimore
  3. Crawling
  4. Scale Builder
AE:
New! SR10M Dirt Oval RTR, Blue - #70033
New to the SR10M Dirt Oval line up, the SR10M Dirt Oval RTR! Sharing the same features from the kit version released previously, the SR10M is great way to get the most bang for your buck! The SR10 class is picking up speed around the country, give it a try with the latest version!
Read all the details using the link below:
https://rc10.com/sr10mrtrfb/
Features:
  • 2.4GHz 4-channel radio with digital frequency hopping system
  • High-torque digital metal gear servo
  • Powerful Reedy 3300kV brushless motor
  • Water-resistant high-power Reedy brushless speed control with T-plug connector and LiPo low voltage cutoff
  • Factory-finished Street Stock body with integrated rear spoiler
  • Lightweight Street Stock-inspired wheels
  • High-grip tires with Street Stock-inspired tread pattern
  • Impact-absorbing front bumper
  • Aluminum 12mm coil-over shock absorbers
  • Durable and lightweight aluminum top shaft
  • New mid-motor low center-of-gravity G10 fiberglass chassis with updated O-Ring battery straps that accommodate 2S LiPo battery packs
  • Updated mid-motor rear carbon fiber shock tower
  • New carbon fiber chassis side braces
  • Updated rear toe block for Dirt Oval racing
  • Adjustable body mounts
  • Rear CVA drive shafts for more reliability
  • 2.6:1 ratio gearbox with heavy-duty sealed gear differential and externally adjustable slipper clutch
  • Rugged steel turnbuckles for adjustable camber and front toe-in
  • Adjustable suspension geometry
  • Vertical ball ends for roll center adjustments, front and rear
  • Many Factory Team options already available!
  • Metric hardware throughout
  • 24 precision rubber-sealed ball bearings
  • #70033C LiPo Combo includes a Reedy LiPo battery and Reedy compact battery charger.
It seems they have improved the transmitter and the windows aren’t painted shut. Threaded collars on the shocks is convenient as well but looks like we’re still missing bleed screws on the shock caps.
